跳转到主内容
苹果2016年对于专业用户的笔记本更新。具有15英寸,2880*1800的Retina显示器, 四核心 Intel Core i7处理器, 256 / 512 GB /1 TB / 2TB 存储空间, 16 GB 内存, 和一个带有Touch Bar的键盘。2016年11月发布,型号为 A1707。
253 个问题 查看全部
Not booting after battery replacement
Bought and installed a battery replacement for my 2016 MacBook Pro, carefully following both the instructions and cautions here: 2016年末带 Touch Bar 的15寸 MacBook Pro 电池更换
After reassembling and confirming everything was connected, I plugged the MacBook in and powered it up. All I ever see is a black screen with battery percentage (64%). I’m at a loss as to what to try next.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Ideally one should try the new battery before installing it and if things aren’t as expected then try again the old one to rule out a faulty battery or possible other damages.
Alternatively, try disconnect the battery and plug-in the cable, with its original charger the Mac should be booting on its own and let you check if at least it still works somehow. If it doesn’t start at all or if it behaves the same with new and old battery, chances are that something went wrong during the repair and the logic board got damaged somehow.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
anonymous 1896 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 7
总计 63
