跳转到主内容
Sixth generation of Apple’s wireless base station, released June 2013. The tower provides dual-band support wireless access and is Apple’s first router with 802.11ac technology.
28 个问题 查看全部
low read/write speed ethernet
i have this model but(a1470) with HDD 2tb USA version, wifi normal but speed write and read is very low(only 10-15 mb/s) instead 40-70 mb/s another users.
COnnected to PC windows with Ethernet and on PC motherboard LAN 1000mb/s
What should i do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论:
question does not give enough info to diagnose.
how are you determining speed?
are you saying wifi speed is normal but Ether speed is not?
Internet speed is upload/download not read/write - what are you talking about?
完成的
添加一条评论
1个答案
Why Your Hard Drive Gets Slow
HDDs and SSDs are commonly used in your daily life to store films, games, and other files rather than with a flash drive or a DVD. However, sometimes a hard drive may become slow to read and write, and for no obvious reasons. To find out the reasons and solve the slow hard drive issue better, you should give you a head start on understanding what causes slow performance.
  1. 1. Torrents and P2P software
  2. 2. Insufficient power or USB ports
  3. 3. Not enough free hard drive space
  4. 4. Logic errors and bad sectors
  5. 5. Damaged disk
  6. 6. Hardware failure...
Now that you have known the reason why the hard drive takes a long time to read, you can follow the fixes to solve your problem and speed up your hard drive easily.
Fix 1. Upgrade the Hard Drive
Fix 2. Uninstall Unwanted Programs
Fix 3. Check the Speed
Fix 4. Switch the SATA
Fix 5. Clean Up Junk Files
这个答案有帮助吗?
得分 -1
添加一条评论
添加你的答案
Alex U 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 19
