跳转到主内容
The Acer Aspire E5 series is a line of notebook laptops manufactured and sold by Acer, Inc., an electronics corporation based in New Taipei City, Taiwan. The Acer Aspire E5 series was introduced in 2015.
recovery disks, are they available somewhere?
My daughter acquired an Acer Aspire v5-122 P 0649. I would like to reset the laptop to factory and go from there. However, the problem is when I go into Disk Management, although all the partitions are there, ie, Recovery - 400MB, EFI - 300MB, Recovery - 350MB, New Volume (E:) Primary - 11.28GB, and lastly, Windows (C:) 226.04GB, with 79% Free Space.... The big problem is all the partitions except for Windows (C:) are 100% Free Space. Even Volume (E:) which lists 11.28GB says it is also 100% Free Space??? It all must be true because I have tried factory reset several times and absolutely nothing... I have searched a lot for someone who has just the factory recovery disks, and nothing... perhaps they don't even exist.. Suggestions?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I would do a clean reinstall Windows, not do a recovery. Recovery, if available, puts it back to the way it came from Acer with all the bloatware. You can download a copy of Windows from the MS site. Then lookup clean install of Windows.
B4 doing this, you must backup all your data files, documents, pictures, videos etc. Otherwise, they will be gone.
完成的
添加一条评论
1个答案
已选择的解决方案
Ignore what Disk Manager says. That is not what you should be interested in.
You will need a USB flash drive or burnable DVD - USB flash drive is easiest and fastest.
Go to Microsoft:
https://support.microsoft.com/en-us/wind...
Select “ Windows 10 (Then select Download tool now.)” on the next screen select follow on screen instructions to make the Windows installations media.
You will want the 64 bit version and probably “Home” edition.
Let us know how it goes. just ask if you need any help.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Richard C 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 753
