跳转到主内容
加入维修社区 - 创建账户
发布于2018年10月26日。型号A1984,A2105,A2106,A2108。 提供GSM或CDMA / eSIM,nano-SIM或双SIM / 64,128或256 GB /黑色,白色,蓝色,黄色,珊瑚色或红色。 (发音为“iPhone 10 R”)
True Depth Camera Issue- Swap possible?
Hi everyone
i have 2 XR’s, 1 main board is damaged, everything else is fine, the other is perfect except during a screen replacement(4th time-lol) the face recognition stopped working. I am always careful and have done maybe 100 XR’s and never had this issue. i was wondering if i could transfer the entire assemble between phones or is it deeper in the system than just transferring both screen side sensors and main body cameras to other phone? the one with the board damage face recognition is perfect, was hoping to just swap it out on the other phone, but if the system needs the originals i guess i have 2 new donor phones - lol
thx
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Maybe an alignment issue
完成的
添加一条评论
1个答案
已选择的解决方案
The front camera and the sensor on the screen are only compatible with the original motherboard they are tied together. I would check your contacts/connections and make sure you dont have a bent pin or a dirty connection. I would also check the cable from the sensor were it makes the 90 degree turn that's the spot that is easy to tear. I can't remember the name of the sensor on the screen I had a stroke a few years ago and sometimes I can't remember names and words but I know that you know which sensor I was talking about. If you are good with microsoldering you can change the chip onto a new cable and it will work.
这个答案有帮助吗?
得分 1
1条评论:
Thx Allan - was leaning in that direction
完成的
添加一条评论
添加你的答案
dave harris 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 21
总计 973
