跳转到主内容
An SSD, or Solid State Drive, is a type of storage device that uses NAND-based flash memory to store data.
Samsung MZ-VLW2560 chip replacement question
Hello,
just out of curiosity. My colleague got its notebook broken (seems something got sort circuited) and it seems it took the Samsung MZ-VLW2560 drive with itself (the drive, connected to external adapter only heats and is not detected).
I had quickly used multimeter over the drive and had found out, that chip S2FPS04X01 A1708 604C858 has several pins connected or shorted to ground. I am not able to find datasheet, but I suppose its some kind of drive IC and since its in QFN-36 body, that only thing connected to ground should be the plate underneath the chip, not the side pins.
Is my analysis correct and if yes, should I search for the chip and try to replace to get the data out (colleague had already “mourned” data loss I only want to try it for learning purposes) or am I completely mistaken?
Thanks,
Regards,
Petr Sourek
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论:
@djmanas it is not the SSD driver IC but a Samsung S2FPS04X01 SSD power management IC which makes sense given the nature of the failure. Your test appears to be the right thing and I would replace that IC and see what happens. If nothing else it'll be a great learning experience.
完成的
@oldturkey03 Hello, sorry for delay. Thanks for comment and "confirmation" that my thoughts are heading the correct way (regardless of result). Just out of curiosity, do you know, where to buy this kind of chips? A will be contacting Samsung, but its always good to know, where to get spare parts (I had tried Aliexpress and found different ones, but I am not able to tell if its the same or not).
Thanks,
Regards,
Petr Sourek
完成的
@djmanas yes Samsung may not be big help on this one. I would try Aliexpress since there are plenty of IC's being sold. Of course, it will also depend on where in the World you are located. Try a simple online search and see if anything pops up that may be close to you.
完成的
添加一条评论
1个答案
One of the biggest misconceptions is the difference between the negative side of a logic circuit and ground. They are not the same!
I can’t directly answer what’s going on here but we look at the these two spaces differently. The negative side connections are often filtered to ground to prevent noise from either entering or exiting the circuit.
Just like your AC outlet/line cords the Neutral side is not the same as the Ground. Each is treated differently, and yes there is a point where the two come together in your breaker panel.
这个答案有帮助吗?
得分 0
1条评论:
Hello,
sorry for delay, got a lot of work. I can see your point and thank you for your insight. But if I am correct, this analysis would need from me to reverse engineering of the whole board, which my knowledge is not capable yet or I would need datasheet for the chip I am mentioning, which would tell me, that the pin is connected to minus part of the board.
I will try Samsung if they will be any help with schematics or so. I had found out, they launched these pages, which are not containing this part, but I got contact for service center.
https://www.samsung.com/cz/support/repai...
Thanks,
Regards,
Petr Sourek
完成的
添加一条评论
添加你的答案
Petr Sourek 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 7
总计 292
