跳转到主内容
加入维修社区 - 创建账户
Samsung 2020 年 3 月发布的旗舰 Android 智能手机 Galaxy S20 Ultra 的维修与拆解信息。
S20 ultra won't charge past
I’ve tried a new charge port, ribbon connectors, wireless coil, and a new battery. Its says that the battery a 0% until I plug it in where it shows a charging symbol. From there I have to press volume down and power to turn it on. Then once its on, it won’t charge past 50%. I wish I knew what is all of the components is connected to charging so I could brainstorm on the issue.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
If it used to be a demo or something check to see is retail is still on, if so try to disable it, then it should work fine, if it was not if it has most of it's storage taken up by ‘system’ then factory reset it, otherwise you might have to put in a new battery or try powering it off and charging it.
这个答案有帮助吗?
得分 0
3条评论:
Lemme know if it any of these work by commenting
完成的
I’ve already put a new battery in it and factory reset it.
完成的
Have you been able to resolve it and how did you do it?
I'm having similar problems. I press volume down and power and then plug it to power it on and it stays at 50% and doesn't charge and drains off when I keep using it. I have changed battery and changed new charging port/panel the same thing happens. It doesn't charge and stays stuck at 50%. What do I do?
完成的
添加一条评论
添加你的答案
Terence Mallett 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 16
总计 531
