跳转到主内容
The 12-inch screen laptop was first sold in mid-2006, and was considered well-equipped, powerful, and ultraportable.
Why do I get strange lines on screen on start up
I have a warning in device manager on the NVIDIA on display area is there any updated drivers? I have tried to find a compatible driver other then the GeForce Go 7400.Could this be related to the lines on start up?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Does your display clear up once it has started? The "strange lines" appear when your OS starts or the moment you start your computer?
完成的
Sorry this isn't an answer, But I have the same problem too and It's only when I turn on the phone
完成的
The phone or the computer?:-) Now nobody will know what hardware you have. You might need to use the "Ask a question" link on the right side of this page and give more information about your device.
完成的
添加一条评论
2个答案
最有帮助的答案
Alian,
I had a similar issue with my Dell Vostro 3700 running a GeForce GT 330M (windows 7 Pro, 64 bit). When I first got it, the screen would flicker and get odd lines on start up, but stabilize after the log in screen came up. Updating my driver took care of the problem, it SHOULD fix your problem. Are you sure your downloading the correct driver (32 vs 64)? Make sure you download straight from nVidia. Do you have your video settings set so that you are using your graphics card and not internal graphics?
Hope this helps!
这个答案有帮助吗?
得分 1
添加一条评论
I found the problem to be the LCD video data cable. More specifically, the fit between the connector on the cable and the connector on the motherboard. I was able to get video without lines after reseating the connector however, heat in that section of the laptop caused the video cable connector at the motherboard to deformed the lines would appear once again.
To resolve the problem, it would require a way to keep the cable connector and the connector at the motherboard to remain in close contact, even as the temperature increased. One way would be to replace the connecters at the motherboard and on the cable. Another way is to force the existing cable connectors to remain in good electrical connection as the temperature increases.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
alian 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 12
总计 4,264
