跳转到主内容
Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
432 个问题 查看全部
White residue on logic board.
When i opened my mac for a ssd install i found traces of white residue on the logic board.
Should i be worried?
Apple support says it's not a defect.
Did ifixit found any on its iMac teardowns?
I thought i saw some traces on the pictures but you must have cleaned it before.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
I found that too, on MacBooks (Pro), especially around larger solder joints. I don't think it's something to worry about, but i still clean then whenever possible. Must have something to do with the kind of solder used.
这个答案有帮助吗?
得分 3
2条评论:
+ You'll also see this on RAM a lot. I've never had a problem with it.
完成的
I have this on a msi graphics card and i think it is something to watch out for because the graphics card stopped working for no reason, it was never overclocked or something, it had only this matte, white gunk on there, had this on a ram stick to but that does still work, i dont know about logic boards though, anyway, its a foreign object that you should clean i guess
完成的
添加一条评论
添加你的答案
Marinus 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 4
总计 1,074
