跳转到主内容
iPhone 3G 的改进版本,具有更快的处理速度。该设备的维修与 3G 类似,需要简单的螺丝刀和撬具。型号 A1303/8GB、16GB 或 32GB 容量/黑色或白色塑料后盖。
Small 'tooth' antenna broken = no wi-fi?
Can anyone tell me exactly what the small 'toothy' looking antenna on the bottom right of the logic board is and it's function?
I've recently moved my logic board into another iphone casing ( if it matters it is a 32GB logic board placed into a 16GB casing with all 16GB trimming ) after a disaster to get it backed up and to see what parts needed replacing to get it back up and running.. all seems to work perfectly except am getting a 'no wi-fi' grey message and unable to connect or even enable it. I know it's not the antenna and must be associated with the logic board as the wifi worked perfectly when I put the original logic board BACK in to see. The small antenna or connector in the bottom right is the only damage that I can readily see has broken off. Suggestions? Thanks in advance.
*also- (unrelated) since the removal the phone will charge on the wall but is not recognized when plugged into the computer, nor will the computer charge it via usb.. again, when original board was put back in it worked fine.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
Matt, any chance you can post an image of exactly where/what part is broken?
完成的
添加一条评论
2个答案
最有帮助的答案
Even with the antenna missing it would still search for wifi.
if its grayed out its the motherboard or a software problem..try upgrading your ios this may fix it but if its a hardware fault you've had it..check to see if you get a mac address for wifi in the 'about' in settings.
这个答案有帮助吗?
得分 2
1条评论:
check your dock connector..for the charge fault..sometimes the pins don't make contact with the charger dock.
try manipulating the plastic dock under the iphone give it a clean
and make sure the black strip on the phone dock is strait and not bent.
完成的
添加一条评论
No wifi detected in about settings :(
Tried cleaning to no avail and and the usb cable charges when connected to the wall but not the computer. Idk.. thanks for the input.
这个答案有帮助吗?
得分 0
1条评论:
Thanks Matt and Ray, this post was helpful to me, too.
完成的
添加一条评论
添加你的答案
Matt 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 1,030
