跳转到主内容
加入维修社区 - 创建账户
于 2014 年 10 月 16 日发布,型号为 A1347 和 EMC 2840。
2014 Mac mini problems
so the fan on my mac mini isnt working causing my system to hit temps up to 90c.
is there away to test the fan to see if it is the fan or the port thats messing up? ether way i ordered a new fan lol
the other problem im having is with email it wont log into any mail providers
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
I would instal this great app TG Pro It will allow you to see the thermal sensors and the fan and if you get the full version the diagnostics it offers might help you on what's needed. Take a snapshot of the main window so we can see all of the sensors and fan data, you may need to adjust the window so you capture all of it. Post it here for us to see 在已经存在的问题里加入图片
完成的
@danj Ok my man just uploaded it
完成的
@zby67 - You'll need to talk with your ISP to properly setup the correct SMTP TCP port (default 587) as many alter it from the default to make it harder for DoS attacks.
Here's a good backgrounder on how Internet mail works Simple Mail Transfer Protocol
完成的
添加一条评论
1个答案
已选择的解决方案
Well its clear the fan its self is messed up! Either its jammed up from dust and debris or just bernt out. Follow this guide to get to it Mac mini 2014年末风扇更换 Use a small soft paint brush and a can of can’ed air to carefully dust out your system using the air sparingly to push-way the loose stuff you created with the brush.
Here’s the needed part if cleaning the fan fails: Mac mini (A1347 Mid 2011-Late 2014) Fan, Apple P/N 922-9953
这个答案有帮助吗?
得分 1
2条评论:
Thank you! yeah i ordered a replacement fan from here already! i also plan on adding new thermal past to the cpu
完成的
@zby67 - Just don't over do it! Many people pile on the TIM when only a very small pea size drop is needed. Think of it this way take a single sheet of face tissue and cut it into the size of the silicon chip (black part), now wet your fingers so you can roll it into a tight ball even thats too big! also note only one chip has paste on it.
完成的
添加一条评论
添加你的答案
Mike Hum 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 337
