跳转到主内容
加入维修社区 - 创建账户
Apple 2020年的顶级智能手机。iPhone12 Pro Max于10月13日发布并于11月13日发布,配备6.7英寸OLED显示屏,带LiDAR的三重后置摄像头系统和5G连接。iPhone 11的后继产品。 专业版
found a broken iPhone 12 max
I'd like to fix this thing and either return it to it's original owner or sell it. The screen is shattered and it does not at all respond when plugged in…..but there seems to be no water damage and the frame appears perfect. i have a $200 quote for a new screen installed. what should I do?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
You could try to see if siri will work and ask her "who do you belong to" and she will tell you about who the iPhone belongs to. That's all she will tell you. You could also try to ask her to call "mom" or "dad", but I'm not sure if the phone will let you use siri after a restart. Now if you don't want to return this phone to the owner and you want to keep it, I recommend reading the answer by Chris Stables. Good Luck!!
完成的
添加一条评论
1个答案
已选择的解决方案
You will have to presume the phone will be iCloud locked. I would connect it to your pc or mac and see if it is recognised, you will probably need to put it into DFU or recovery mode if it has a passcode.
The only way to find the owner would be if it has not got a passcode and you can view there information but this will be highly unlikely.
 You really need to find the lock status before spending any money. You could try restoring it via 3uTools or iTunes and see if it will activate, you shouldn’t need a working screen for this. Or see if there is an IMEI number on the sim tray which you could check on a website.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Kurt Schasker 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 23
总计 513
