跳转到主内容
加入维修社区 - 创建账户
Moderl Number: RCA LED46C45RQ
TV Doesn't Turn On, Standby LED Lights
Hello everyone, this will be my first post here.
Model Number: RCA LED46C45RQ
I salvaged an RCA 46” TV that has an indicator light, but doesn’t turn on when the power button is pressed. When I go to plug it in, the power supply draws power and I can hear the typical electrical arc hiss when the AC prongs bridge; so clearly it doesn draw some power. The Red LED lights, but the LEDs do not come on at all when plugged in, or when the power button is pressed.
However, when the power button is pressed (the power button is “clicky”, so it’s not a bad button), the TV does not light. This is also true if I hold the power button or press multiple times. I don’t have the remote for it, but given that it doesn’t apear to function when the power button is depressed, I don’t think it is necessary for solving this issue. There are also no LED indicators on the board to tell me if certain boards have power.
Here are some pictures I took:
I have a multimeter :)
What approach should I take to restore the TV?
Update (12/27/2021)
Sorry for the delay, work and life complications.
I thought that the power board was the issue due to it not complying to the power pin requirements written on the board, but the replacement board that I got has the same issue. I believe these to be some kind of standard.
Anyway, I’ve replaced all boards on the TV (the 2 pictured), but the TV still does not light. The power indicator will toggle on and off depending on the switches on/off status, but no signal on the TV itself.
I believe it to be an issue with the LED array or something. Is there anything I should check aside for all connections to the board and AC power (which were double checked first obviously (as was the LED indicator)).
Not sure where to go from here.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
7条评论
@magossarah since you have no sign of life on this TV you want to start with the power board. Make sure that the fuses are intact and visually inspect it for damaged components. Check the rectifier diodes. Let us know what exact model this TV is.
完成的
My bad, I just noticed upon further inspection that the standby indicator LED does light. I have edited the question accordingly. No fuses are present. The exact model number has been posted.
完成的
@magossarah since your power LED comes on I suggest that you measure the voltages from the power board to the main board. Compare those voltages to what is listed for that connector on the power board itself. Remember that your power board supplies the voltages but it is actually your main board that tells the TV to turn on after you push the power button (simplified)
完成的
I'll do that, although I'm not sure the multimeter probes are thin enough to reach the contacts inside the rectangular plug.
There are multiple replacement boards that I can get on Ebay for about $30 to replace the LED driver board. The only thing is that while they look the exact same, they technically have different numbers. They have the same connectors in the same places.
In your opinion, do you think they are interchangable?
完成的
@magossarah that is a tough one. I have had issue with different versions of boards even so they were identical. Even minute changes could become a problem. Before changing any board see of you can find the bad one first. I‘d hate to soend your money on a wrong board etc. if your meters probes dont fit the connector, use some small objects like thin nails etc. and insert those (power off of course and make sure they do not cross) then power up and measure carefully on those. My gut feeling says its the main board but my gut can be wrong ;-)
完成的
显示更多的2条评论
添加一条评论
2个答案
最有帮助的答案
I found the issue with the multimeter. The +12V and +5V rails were dead. So it's the power board.
这个答案有帮助吗?
得分 1
添加一条评论
in some cases it would be the signal board (where your rca cables and hdmi’s are).
but not in this case. you have a bad panel. the led lights are shorting and are out. therefore screen is not lit. replacing the screen (panel) is not feasible for repair. you can order the led’s. many a times this (replacing the led’s) is a complete loss of time and money. when under warranty, we would receive a new panel. install the original tv boards into the panel for a complete repair. thank you for asking. matt of martins tv repair.
Update (12/24/2021)
KEEP US POSTED, WANT TO SEE IF THIS IS CORRECT.
这个答案有帮助吗?
得分 0
1条评论:
Does this TV support WiFi
完成的
添加一条评论
添加你的答案
MagosSarah 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 8
过去 30 天: 43
总计 1,973
