iMac 27 2013 (3 Beeps for RAM Issue) Tested other RAM and no luck
Hi, I have a 2013 iMac 27” i7 model that has an issue with I believe the RAM judging by the 3 beeps its giving. I tested all the memory separately and also tried other modules of RAM in different slots from other working iMacs but still won’t power on and 3 beeps. Have already done reset SMC, tested a different cable but no luck.
Would anyone know if it could be an issue with the logic board?
The iMac was in sleep mode and then the next day restarted in the afternoon so something must have triggered it to restart and start beeping.
Any suggestions of help are much appreciated, please.
Thanks kindly :)
2条评论
Review these:
∙ If your Mac beeps during startup
∙ Startup tones, EFI, and fixing failed firmware updates
由 Dan 完成的
Thanks Dan, so yes I am getting
One beep every 5 seconds
(Your Mac isn't detecting any memory (RAM). If you recently added or replaced the memory, make sure that it's properly installed).
Tested multiple different memory and still the same issue with the beeps.
由 Adrian 完成的
