跳转到主内容
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
418 个问题 查看全部
will the later 2007-2008 lower case fit a 2006 core duo?
The battery hold down lock in my 2006 core duo is defective. I do have a few nonworking 2007-2008 Core2duos at hand with good lower cases. Are they interchangeable? Ifixit’s parts numbers are different, but maybe there’s a hack that will work?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
I am 100% sure it will work
这个答案有帮助吗?
得分 1
添加一条评论
Assuming you'll be porting over all of the other internal components (the heatsink, the fan, AirPort card, MagSafe board, battery connectors), etc, it should be possible to transfer your Core 2 Duo motherboard over. The main thing to be watchful for is that the screw standoff positions may be different in the Core 2 Duo A1181 bottom case. The easiest way I can think of is to look at the compare the final images of the bottom case for the iFixIt Lower Case replacement guide between the Core Duo and Core 2 Duo MacBooks...but even then you potentially won't know for certain without attempting the replacement.
If the screw positions do differ significantly, you may have to cut any conflicting screw bosses off of the bottom case (i.e. with a Dremel) to accomodate the motherboard.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Bernie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 30
