跳转到主内容
The HP Elitebook 1040 G4 is a 14” laptop powered by Intel. The Elitebook 1040 G4 was released in September of 2017 and ranges in price from $1400 to $3400 roughly.
Black screen, capslock and numlock flash 5 times
I have an elitebook 1040 g4 that I got as a failed laptop, I had it working intermittently for a while, then it stopped completely.
When I started looking at the issue, I took the board out, found I had knocked a diode off the board.
I've resoldered the diode, seems to be connected and passes a diode test on the multimeter.
Frustrated, can't find a schematic, not sure what's what.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
This may help:
Disconnect the power supply and power the computer with battery power. This resets the Embedded Controller/Keyboard Controller.
  1. Unplug the AC power from the computer.
  2. Press and hold the power button for more than 12 seconds.
  3. Release the power button (after at least 12 seconds).
  4. The computer powers on and should boot normally.
  5. Re-connect the AC power to the computer.
Source: https://support.hp.com/us-en/document/c0...
这个答案有帮助吗?
得分 2
3条评论:
I don't know why this is the go to solution for this issue because it doesn't work.
I should have added that I have tried this already.
完成的
Not having a go, and appreciate all input on this issue, but there's a ton of YouTube videos that also say this that. Some of my reading on this issue is that I might be missing a power supply. Does anyone know the best test points and what voltages to expect. I have battery voltage, 3.3 and 5 and 1.8 and some lower voltages.
完成的
@moondog77
Yes you should have. Saves us time and energy.
完成的
添加一条评论
添加你的答案
Keith Moon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 26
总计 1,354
