跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
Not Showing in ITunes
I have just replaced the front screen, home button, dock connector and rear cover on my iPhone 4.
Everything appears to be working, including the charging, except when i connected to iTunes, nothing appeared under devices, and therefore can't update music or sync the phone.
I am running Lion on my Macbook, and my other phone syncs with iTunes , no problem.
Please could anybody help with this dilemma. Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
Thanks for all the replies. If I disconnect the new dock from the logic board but leave it screwed to the iphone, will I be able connect the old dock connector, and leave it loose, but connect the USB lead and check iTunes? At least that will prove the new connector is faulty! Thanks
完成的
添加一条评论
3个答案
已选择的解决方案
check that you have connected all fully, if that checks out I'd ask for a refund, as long as you have treated the dock well trying to replace it, then there is no other reason apart from faulty part.
这个答案有帮助吗?
得分 1
1条评论:
I contacted the supplier, and they sent me a new Dock Connector. I fitted the Dock and My iPhone now Syncs perfectly with I Tunes. THanks for all your replies.
I found that you can remove the speaker housing and dock connector, without removing the logic board, if u are very careful! But please note that there is a chance of damaging the logic board, so be careful. Thanks
完成的
添加一条评论
Put it in update mode. Here's how to do it. First,press the power and home button simultaneously. Then after about 7 seconds release the power button. It should say connect to iTunes. Then plug it into your computer and restore it. It will delete everything on the phone and put the most recent version of iOS on it. If that doesn't work try examing the connector and see if it's plugged in.
这个答案有帮助吗?
得分 1
添加一条评论
try to reboot the phone, if still it doesn't work.
then check if your dock connector is damanged.
guide to change the dock
这个答案有帮助吗?
得分 -1
添加一条评论
添加你的答案
jason 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 1,105
