My right rear window won’t go down.
My driver side rear window won’t go down on my 2009 GMC Acadia. All other windows work except that one. I changed out the motor and regulator but still didn’t work. The switch has power to it and it clicks when I push it and nothing. Any suggestions?
cristina27 do you get power from the switch to the motor? Run a jumper from the Switch contact B+ (Green wire?) to the blue wire on the motor. see if that driver your window up. If it does you know there are issues with the switch.
由 oldturkey03 完成的
