跳转到主内容
Repair information and guides for the CDMA version of the fourth generation iPhone. Model: A1349 / 8, 16, or 32 GB storage capacity
295 个问题 查看全部
Where do these 3 clips go? Verizon iPhone 4 rebuild. Help!
There are three clips, maybe grounding or antenna clips and i can't remember where the go, i am pretty sure the solid brass/gold one goes on the top of the logic board, and one goes on the battery screw, but there is a third as well.
Are there any pictures that show where these go? Originally i had tried to just replace the glass, but in the process the LCD assembly fell apart, so i order the glass/LCD combo replacement.
Thanks for any advice and help.
Mac
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
You can see two of them at step 17 and step 22 of the logic board guide here :
iPhone 4 Verizon Logic Board Replacement
这个答案有帮助吗?
得分 3
添加一条评论
The 3rd and 5th pictures are of the same part (camera ground). The part in the 2nd picture is in step 10 of the same document (logic board pressure contact)
Installing iPhone 4 Verizon Logic Board
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mac MacAnanny 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 4,577
