跳转到主内容
Repair guides and troubleshooting for dishwashers made by Electrolux.
10 个问题 查看全部
What does code i11 mean?
When I start the Dishwasher, it makes a few starting sounds, counts down 4 or 5 minutes, then stops and shows error i11. What’s wrong with it? (A few weeks ago, it already stopped opening the door for the last bit to dry dishes…)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
@muellerin what is the exact make and model number for your DW? What have you checked?
完成的
添加一条评论
2个答案
最有帮助的答案
Apparently code i11 indicates a fault in the drain pump or drain valve. This may not be entirely accurate.
这个答案有帮助吗?
得分 1
添加一条评论
i10 and i11 are water filling related. The machine could not add (enough) water.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Ina Müller 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 11
过去 30 天: 49
总计 1,569
