跳转到主内容
How to convert DE keyboard to US keyboard?
I am currently located in Germany, which uses a local keyboard layout. As a programmer, I would like to have a US (ANSI) layout (UK (ISO) keyboard would also be ok) for my MacBook Air (late 2020), how can I go about doing it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
To start with the uppercases between the US and ISO systems are different! As the Return and shift keys are physically different.
So the only way to convert your system is replacing the uppercase assembly which I don’t think is worth the risks as these systems are so new we still can’t get the parts and if you review these guides you’ll see its not easy trying to take the battery out to swap over MacBook Air 13 英寸 Retina 显示屏 2018 年末电池更换 and moving things over MacBook Air 13” Retina Display Late 2018 Upper Case Replacement I would personally not try moving the battery as remounting it will be difficult without the glue tabs.
  • Top Case & US Keyboard - Space Grey, Apple P/N 661-15386
  • Top Case & US Keyboard - Silver Apple, P/N 661-15387
  • Top Case & US Keyboard - Gold Apple, P/N 661-15388
I really think you want to stick with the skin or stickers or find a US model and sell your german unit.
MacBook Air 13” Retina Display Late 2018 电池图片
指南
难度:
中等
30 minutes - 1 hour
MacBook Air 13” Retina Display Late 2018 Upper Case图片
指南
难度:
中等
1 - 3 hours
这个答案有帮助吗?
得分 1
2条评论:
This seems to be a nightmare, would a conversion to UK (ISO) layout be easier? I would be ok with it alternatively.
完成的
Not any easier! All you're doing is swapping out the part from US to ISO now ISO to another ISO uppercase.
The other option then is swapping out the keycaps but I'll worn you it took me over a dozen keys to get a replacement mounted back. So you'll need to get a couple of sets as I'm sure you'll damage a few in the process!
In the end given the number of keys needing to be altered really doesn't make sense
Apple Key Caps UK There is no US ISO listed and as you can see the availability is thin at this point in time!
完成的
添加一条评论
最有帮助的答案
The easiest way to do this would be stickers, laebls. or a keyboard cover.
First, go to System Preferences>Keyboard>Input Sources and click the plus symbol at the bottom left. Select your desired language.
Then put the keyboard cover, stickers, or labels on.
You can change the keyboard layout by going to the top right corner by volume, clicking the flag, and choosing the desired keyboard layout.
这个答案有帮助吗?
得分 2
2条评论:
I wanted to avoid stickers/covers once I want to keep the feel of the keyboard as the original. But thanks for taking the time to answer.
完成的
you can convert iso to ansi layout just with stickers... they have a different key layout. also ansi has one more key
完成的
添加一条评论
添加你的答案
Gabriel Lencioni Lovate 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 18
过去 30 天: 66
总计 5,044
