跳转到主内容
苹果的iPod Touch第六代于2015年7月发布。
What is the middle battery connector for?
After Ipod touch battery replacement the battery has been getting stuck at 19% or less
then when it gets low enough the ipod shuts off,
and it take a while to get it to start up again with it plugged in,
Is it possible i got a defective battery?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
14条评论
@beanman56 it's possible. where did you get it from?
完成的
I got my battery from ifixit,
so whats the middle connector for?
完成的
@beanman56 On the 6 gen I am pretty sure the centre pin is the battery data.
完成的
Is it needed?
Cus it was ripped off the board
完成的
@beanman56 Usually one or more pads come off when this happens. How’s you’re soldering skills?
完成的
显示更多的9条评论
添加一条评论
1个答案
已选择的解决方案
Hi
Hope you are well
I did not know really know how to explain this but I had a 6th gen that had the middle battery connection ripped off from previous repair and I noticed that mine would get stuck at 17% and when it would die it straight up wouldn’t charge again but there are test pads above the 3 battery pads and I found the one in the photo had a connection so I ran a jumper and it started working again so hopefully my complex explanation as helped
Anymore questions please ask
这个答案有帮助吗?
得分 2
10条评论:
Whats a jumper
完成的
@beanman56 A jumper is copper wire that you use when a trace or pad is broken between components. The average size wire is 0.01mm
完成的
@hellomacos - Ok i see
完成的
@hellomacos - What size should said jumper be?
完成的
@beanman56 where you been Sir? Doing ok?
完成的
显示更多的5条评论
添加一条评论
添加你的答案
Ben Capehart 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 586
