跳转到主内容
加入维修社区 - 创建账户
Also sold under the GMC Sierra and VIA Vtrux names, available in the US, Canada, Mexico and other countries around the world.
Backfiring chev please help
Ok I have an 04chev Silverado 5.3L,that’s backfiring while on cruise.changed plugs and coil wires and camshaft,also changed crankshaft,and now after putting new wires and plugs it has now started flooding.what is the problem here please??
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Are you sure you're using the correct plugs and that they're gapped properly? I ask because if you just changed them, and as a result it is flooding... might be something with them.
完成的
johanneshere "camshaft,also changed crankshaft" I hope you meant the camshaft and crankshaft sensors. Have you scanned the OBD yet? Any codes?
完成的
添加一条评论
1个答案
If you haven’t already, check your timing belt. If your valves are opening at the wrong times, fuel could be getting into your exhaust and combusting too late, causing the backfiring.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
joanneshere 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 22
总计 124
