Belt squeaking at higher rpms
my 1994 chevy suburban C1500 has an annoying belt squeak. The tensioner seems to be working fine, and I replaced the belt with no change. What could.be the problem?
Take the belt off, and check the pulleys…I am sure either the free pulley or tensioner pulley is squeaking. Replace it.
这个答案有帮助吗?
Check them how? I pulled the belt off and moved each one. Nothing squeaked when I manually moved them, and none had any wiggle to them suggesting faulty bearings or internals.
过去的24小时: 0
过去的7天: 0
过去的30天: 6
总计 116
Hi @brandon_k ,
Don't know the engine but it's not the alternator, water pump, (A/C compressor?) is it?
由 jayeff 完成的
Not from what I can tell. It has the 5.7L 350 with TBI. The pulleys for all seem steady, no wobbling. Tension seems good, tensioner moves. If I spray a little armor all on it it lessens the squeaking.
由 brandon k 完成的
@brandon_k the water pump loves to squeal on these just before it gives out. Check on that as well as the bearing of your tensioner.
由 oldturkey03 完成的
@oldturkey03 it sounds like a herd of crickets when accelerating, mostly over 1200rpm. Is this consistent with the water pump about to give? It definitely sounds just like belt squeak. I'm fairly new to this engine so I'm not so sure about things. Is that what the water pump would sound like? The tensioner from all appearances is good. Its also fairly new.
由 brandon k 完成的
@brandon_k it did on mine. It was quiet during idle but if the RPM's went up it started to squeal. I know it's a pain to get to it but try and instead of spraying lube on the belt, spray some on the individual bearings of the accessories i.e. water pump, alternator, steering pump etc.. You'd have to do one at a time to hit the right one. What ever you do, please make sure you stay safe around the belt. I have seen people getting slapped across the face by breaking belts while the engine was running and it ain't pretty.
由 oldturkey03 完成的
显示更多的24条评论
