跳转到主内容
苹果2016年对于专业用户的笔记本更新。具有15英寸,2880*1800的Retina显示器, 四核心 Intel Core i7处理器, 256 / 512 GB /1 TB / 2TB 存储空间, 16 GB 内存, 和一个带有Touch Bar的键盘。2016年11月发布,型号为 A1707。
253 个问题 查看全部
MacBook Pro 15 late 2016 no backlight
I have this problem on my 2016 Macbook Pro but I don’t think it is related to FlexGate for two reasons:
  1. It has pretty much been a desktop its whole life, closed maybe 10 times. I have a second 2016 Macbook Pro that I use for travel.
  2. It hasn’t and currently doesn’t show any of the FlexGate symptoms such as backlight on when barely opened or stage lights.
Is there another suspect component that could cause this failure, perhaps user serviceable?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Jim Sorrels exactly what symptoms does your MBP show and what have you checked?
完成的
添加一条评论
1个答案
There is logic within your logic board which powers the backlight LED’s within the display. While its possible that has failed. This series mostly had the FlexGate problem like the 13” model.
Sadly, Apple never fessed up about it on the 15”. It was less of a chance than the 13” models and it often happened on systems like yours! The display sitting around 45º angle as that was the high stress point on the cable.
Give this a view MacBook FlexGate Fix / Repair: What if the cable is +3mm longer?
In any case I would find a good MacBook Repair person who knows these systems at the deeper level to check if the cable is the issue or if the backlight power circuit needs repairs.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jim Sorrels 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 65
