跳转到主内容
Nothing happens when you press power button?
I can't get anything to happen when I press the power button
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
tested 110 vac coming into power supply but nothing coming out of out put side.
Thanks David
这个答案有帮助吗?
得分 0
2条评论:
完成的
添加一条评论
最有帮助的答案
I've got to ask some questions to be able to help. Do you get any lights at all? If so, do they flash? If they flash, how many times? Any sounds?
Thanks
这个答案有帮助吗?
得分 1
2条评论:
Open the back by removing the three screws in the bottom of the frame. Plug it back in. See if any of the LED lights in the middle of the board are on. Just to your left of the lights should be two small gray button. Using a pencil eraser tip hit each one and set if the machine turns on. One is the reset & one the start up and let me know if you get any results.
完成的
mayer, once the iMac is open he could check for bulged or leaking capacitors don't you think ?
完成的
添加一条评论
There are no lights at nothing happens.
I think it is power supply but not sure.
Thanks David
这个答案有帮助吗?
得分 0
3条评论:
There are three main failures with this machine. First was the power supply, look for burn spot. The second was bulging and corroded capacitors, look at the 25 cans. Third is a older separation on the GPU chip that gives video problems. If your capacitors show symptoms and your power supply is gone the it is not worth trying to fix this machine. Let me know and if needed I'll go into how to transfer your data to a new machine.
完成的
noticed heat under where power supply .
I inspected motherboard and no problems found.
also hard drive on this machine was wiped clean and tested fine,ram tested fine,dvd and fans tested good!
I have another power supply ordered so I think i will give it a try.
完成的
Please look at the bottom of your iMac stand and send the information. We may not have your correct machine listed.
完成的
添加一条评论
添加你的答案
David Payton 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 9
总计 2,029
