跳转到主内容
2020年4月宣布和发布的第二代iPhone SE的维修和拆卸信息。
Taptic Engine Motor weak vibration
Hi!
I have Changed Back Housing on an iPhone SE2020 which previously was bent. After that I have fitted back everything and I have tested vibrator motor but it is very weak. It makes very tiny sound or vibration but it is not normal.
I have tried an 2 good iPhone 8 Taptic Engine but it is the same problem.
Every other function of the phone works perfect except this.
The board has no damaged components on it.
Any suggestion how to diagnose or move forward? Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
I have never encountered this problem being a logic board issue. It will be a parts issue. Install the logic board into a known good housing and test.
这个答案有帮助吗?
得分 1
3条评论:
I've done it already.... Drives mad
完成的
Problem still exist
完成的
Strange to me, I did as well never encountered this problem before....
完成的
添加一条评论
Do you have access to a microscope? It is possible that the board could have sustained damage that is not visible to the naked eye. I would also try cleaning any connections it uses.
这个答案有帮助吗?
得分 0
2条评论:
YES! I have checked under Microscope. Also checked the ARC IC chip and checked did readings no short found.
For now I have ordered another new Taptic Engine to check.
完成的
Also checked with NEW dock flex which did not resolved the problem.
完成的
添加一条评论
Hi, i have similar problem, but my Taptic Engine go laud non-standard, i even order new housing and the solution for me was changing the dock connector. If you have access to new one? You need to instal to the phone to proper test it.
这个答案有帮助吗?
得分 0
1条评论:
I have a spare dock flex. I have tested as well but problem still not resolved. today I have ordered a brand new dock flex I will check if that make any difference.
完成的
添加一条评论
添加你的答案
Peter Hupuczi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 19
总计 451
