跳转到主内容
加入维修社区 - 创建账户
Nintendo DS 的后继机种 Nintendo DS Lite 于2006年发布。这款设备的拆解和维修十分简单。
Nintendo DS won't turn on. Green light flashes then turns off.
I am trying to fix a Nintendo DS Lite but not sure what the problem might be, and what to try to narrow down the issue.
When the power adapter is plugged in the orange light turns on so I don’t think the power adapter is the issue.
When I flick the power switch the green light comes on, then gets slightly brighter. Then the lower screen flickers (what I assume to be the backlight) and it switches back off (with the green light off and the orange one still on) This behaviour is the same without the orange light when not plugged in to the power adapter, so I assume it is holding at least some charge?
Any help would be much appreciated. Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hello! I had this same problem when doing a shell swap on my DS Lite and also repairing an original DS. This happens when the screen ribbon cable is ripped or the screen is broken. I would check both screens and ribbon cables and make sure they are both plugged in all the way. I was able to fix this problem with my DS by taking out the top screen ribbon and plugging it back in. Good luck with your repair!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mayank 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 24
总计 744
