跳转到主内容
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
1187 个问题 查看全部
Help finding a specific screw- a 4-5mm T4
Need to find a longer version of the battery connector screw.
The hole is stripped at top and screw isn't long enough with the connector in place to hold now. Without the battery connector in place, the screw can reach the parts of the hole that aren't stripped, so I think a longer version of the same screw would work.
Any idea how to find that (or another compatible slightly longer screw)?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Can you take a picture of the area where the screw is located so we can properly identify it 在已经存在的问题里加入图片
完成的
@danj done, and thanks!
完成的
添加一条评论
1个答案
最有帮助的答案
OK this is a 3.7 mm T5 Torx screw, so you need at least a 4.0 mm screw.
Take the longer Fan screw (5.0 mm T5 Torx) see if that will work, don’t bottom it out as they could damage things just see if it grips. If it does you’ll need a to get a fan screw set 13” MacBook Pro Screw Set - Fan (x3) Reference Step 14 in this guide 替换MacBook Pro 13‘’Retina显示器2015年早期版本的主板
Now to properly fit it you’ll need a metal file to carefully file down the shaft so the screw is properly flush with the top of the part. Remember it doesn’t need to be tight, use some nail polish to lock it down.
这个答案有帮助吗?
得分 2
1条评论:
@danj thanks for all your help! unfortunately, the fan screw is too thick. It seems like on my mac the battery screw is a T4. Do you know where I could find a 4-5mm T4 screw? I've been looking for one, but no luck so far.
完成的
添加一条评论
添加你的答案
rachel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 110
