跳转到主内容
型号A1989,EMC 3358.更新了现有设计、处理器选项并且更换新的键盘材质.有银色和深空灰色可供选择.于2019年5月发布.
Not booting unless plugged in. But...
My MacBook Pro won’t boot unless plugged in, when I do plug it in I don’t have to even press the power button for it to turn on. However after removing the charger it will turn off after 1 minute usually. It is showing that it’s charging, it’s currently at 80%.
There’s also an issue with the screen, there’s a thick line that is high contrast, and when it gets hot it goes to a lower contrast.
I’ve tried Resetting SMC and NVRAM neither helped.
There was a recent spill, however it was cleaned up deeply internally and there wasn’t a boot issue until I put it back together. The screen issue was there immediately after the spill but a lot worse, I could even read anything as it was a fully broken up image.
When I check the cause of shutdown they are all okay except for when I unplug, it says -14 which I’ve read is a power surge. Any ideas would be really appreciated.
Update (10/08/2021)
This is the coconutBattery screenshot
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Can you download CoconutBattery(https://www.coconut-flavour.com/coconutb...) and take a screenshot of the main page of the app?
完成的
@andrewsawesome I updated with the picture in the comments
完成的
添加一条评论
1个答案
Sadly you need a new battery! The number of cycles has exceeded its 1,000 cycles the battery is rated too Determine battery cycle count for Mac notebooks.
Given the systems age you are a heavy remote user. You tend to let the battery run to empty and then charge it. Each time to let the system get past the 2/3 point your battery needs to work harder to charge it and burns a cycle. The number of cycles wear the battery.
Here’s the needed part MacBook Pro 13" Retina (A1989, A2251) Battery and here’s the guide to put it in 2019年带Touch Bar的13寸MacBook Pro 电池更换
产品
$119.99
这个答案有帮助吗?
得分 0
2条评论:
@danj I was thinking that, however, the battery was just fine before. The chance that the issues are connected is slim. The problems happened on the same day.
I will look into getting a new battery, I was already aware that the cycle count was too high.
完成的
@creedd - I'm sure what ever was spilled didn't do you any favors. Maybe its time to backup your system and get a new system.
完成的
添加一条评论
添加你的答案
Creed 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 396
