跳转到主内容
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
Newly installed SSD very slow read/write speed
Hello,
Today i installed a new SSD into my macbook pro early 2015 (A1502). The name of the SSD is Western Digital Blue SN550 500GB. When i do black magic speed test i only get 400 MB/s write and 1350 MB/s read…. even the standard SSD is faster :( I already tried changing the startup disk and i enabled Trim but no change in speed. I don’t know what to do to increase the speeds of my new ssd.
Thankyou for helping me!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Already found the answer MBP-2015 has pci gen 2 that’s why the ssd is slower than normal.
完成的
@vk007 - You really need to get a SSD that's designed to work in your system. Here's a good guide on the custom Apple SSD's The Ultimate Guide to Apple’s Proprietary SSDs
As @mayer pointed out you also have OWC and you also have Transcend JetDrive 850/855.
All three are good options. I personally don't recommend using M.2 SSD's with the fangled adapters as they often don't work well or lifespan is short as some of the lines Apple has in its interface are not active within M.2 SSD's
完成的
添加一条评论
1个答案
最有帮助的答案
This drive was built for PC machines and not for Macs. You need a drive that is built for a Mac such as the OWC blades.
MacBook Pro and MacBook Air (Mid 2013 to Early 2015) Blade SSD Upgrade Bundle
https://eshop.macsales.com/upgrades/macb...
Here’s Apple Support on this:
https://discussions.apple.com/thread/251...
Upgrade your MacBook Pro or MacBook Air with a new SSD to dramatically speed up your machine, and use your original SSD in an external enclosure.图片
产品
$199.99
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Vishal Sewradj 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 994
