跳转到主内容
2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
Why is there vertical lines on the left side of screen
There are vertical lines on the left side after a letter opener was closed up in the mac { letter opener in same location , left side near hinge] . Now if I just touch the screen in that lower left screen area . . . the lines will change . common sense tells me this is screen damage . When I touch the screen [ gently ] and putting no pressure on the hinge and any connectors ect. . . the lines change . Is this screen damage or the wires in the hinge ? There is no visible damage to the screen .
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
The LCD panel is a sandwich of two glass plates. the back one is a bit more brittle and often cracks before the top one which you can see. The reason the back plate is more sensitive has to do with the processing it gets. It is etched and plated with metal oxide traces which route in an X-Y structure the signals which turn-on/off the discreet pixels.
So with that understanding the lines you see are the micro fractures within that plate signal pathways so the signals are being interfered with. As you touch or shift the display you are allowing the connections to make and break and depending on what the line was to drive, you’ll see different colors or just black.
Bottomline you need a new display 15” MacBook Pro A1398 Display Assembly, Apple P/N 661-8310. Here’s the guide to put in on MacBook Pro 15"(2013年末)(Retina显示器)屏幕组件更换
这个答案有帮助吗?
得分 2
2条评论:
Thanks for the very good response that and this web site are a real help .
完成的
@jmcobuilders - Don't forget to score the answer and accept it - Thanks!
完成的
添加一条评论
添加你的答案
jimcornish@sbcglobal.net 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 255
