跳转到主内容
加入维修社区 - 创建账户
The Samsung Galaxy Note II is a smartphone noted for its combination of a large display and software optimized for an integral self-storing stylus.
Won't power on and no charge light
Was working when I put it in a drawer, pulled it back out after maybe a year and it just won’t power on or give an led indicator it is connected to power.
Tried the cord I had been using in the past to charge it and nothing, cord is fine.
This was a replacement phone I had used for less than a year, it was stored with the battery installed, no leaks, water damage or drops and has lived in a otterbox since day 1.
Wasn’t rooted or custom firmware either.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
John Redkurn follow the official Samsung troule shooting flow chart.
The inoffical thing to do is to change your battery. It has discharged below its charge threshold and will no longer hold a charge. After that, re-evalaute.
这个答案有帮助吗?
得分 1
2条评论:
Issue is it won’t power on even without the battery installed.
I cannot recall if I’ve had it powered on in the past without a battery, so I will ask.
wouldn’t it power on while connected to the charger or other power source without the battery?
完成的
John Redkurn in theory yes in practice it may prevent your phone from coming on if it shortens out or is reported as follows. Again it is part of tge troubleshooting as well.
完成的
添加一条评论
添加你的答案
John Redkurn 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 38
总计 285
