跳转到主内容
A1708/EMC 3164—于2017年6月上市,这台入门级MacBook Pro保留了它的传统功能键(相对于OLED触控条)。
Back light problem procedure to fix it
I have a Back light issue and I requested APPLE for a free repair which was turned down by them.The service provider in India says the problem will not get solved by changing the flex cable alone we need to change the display board also, it is an expensive option. Kindly guide me please Narayanan Lakshmanan India
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
The Flex cable issue Apple was covering under an extended Warranty 13-inch MacBook Pro Display Backlight Service Program. Are you sure you saw the Stage Light effect as described here: The Design Flaw Behind MacBook Pro’s “Stage Light” Effect then it should have been fixed under warranty.
Did you bring your system to an authorized Apple Dealer? If you did and you are very sure then you’ll need to escalate your issue up the food chain as they should have fixed it!
Sadly India has a few fake Apple dealers which mimic the Apple Stores almost to the letter! So its hard to tell if its real and if you ask them they may even tell you they are.
Go to the Apple web site and locate the store nearest to you there. If you don’t see one then there just isn’t one! Again, I would contact Apple and tell them they have someone masquerading as real and they aren’t.
Otherwise let’s dig a bit deeper here:
  • Did you try connecting your system to an external monitor, did you see your desktop and it’s icons?
  • Did you try pressing a lit flashlight against the display at a sharp angle and could you see your desktop and it’s icons?
Replacing the display assembly is not overly hard as you can see here in this guide 2016后期带功能键的13寸MacBook Pro显示屏组件更换 the trick is finding a display locally.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
N LAKSHMANAN Chettiar 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 7
总计 513
