跳转到主内容
2.2 GHz (Turbo Boost 最高可达 3.4GHz), 2.5 GHz (Turbo Boost 最高可达 3.7GHz), 或者 2.8 GHz (Turbo Boost 最高可达 4.0GHz) 四核 Intel Core i7 处理器 ,配备 6MB 共享三级缓存。
MacBook won't recognize charger. Logic board?
Hi everyone,
Hoping for some guidance. I have a 2015 Macbook Pro 15 inch that was working fine. All of a sudden yesterday the machine powered off suddenly, when it rebooted the fans were running super high (loud) which was unusual. It booted back up and afterward I noticed the charger light on the magsafe 2 wasn’t lit at all. I was about to sleep and thought maybe the charger came unplugged or died.
Next day I started the machine up and noticed the battery indicator wasnt showing in the Mac menu bar, light still not showing. I check all settings and they were correctly set to show battery but it wasn’t. I tried to reboot into Win10 (Bootcamp) but it hung on Windows loading screen. (Was going to check battery indicator there)
I rebooted and tried to go into diagnostics but it said battery couldn’t be detected. I rebooted the machine again, got to iOS, still no battery then the laptop shut off and showed the plug in charger screen (battery is dead)
I followed all guidance on this post (Battery not detected, won't charge; strange connector on logic board?) including disconnecting battery, resetting SMC etc and nothing worked, still won’t recognize the charger. I purchased a brand new charger so I know it’s not the magsafe.
I can still power it up but it goes to the screen showing dead battery. I disconnected the battery from the motherboard and connected the charger and still won’t recognize it.
Based on this, is it safe to assume its a dead logic board or something? Obviously an assumption but just wanted to get thoughts. Wondering if its worth repairing or if it’s likely going to be cost prohibitive and should just look to potentially replace.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Lets take a look at the the systems MagSafe connector. Take some pics so we can see how it looks and port them here so we can see as well 在已经存在的问题里加入图片
完成的
@danj Hi Dan, I've attached some photos, I dont see any visible signs of issues in the magsafe port.
完成的
添加一条评论
1个答案
最有帮助的答案
I would start off by using a cotton swab moistened with isopropyl alcohol to clean the white insulator area to make sure the connector is able to fully seat.
Next I would replace the MacBook Pro 15" Retina (Mid 2015) Right I/O Board as well as the MacBook Pro 15" Retina (Mid 2015) I/O Board Cable
Here’s the needed guide: 替换MacBook Pro 15‘’Retina显示器2015年中期的I/O板
Replace an I/O Board Cable compatible with the Mid 2015 MacBook Pro 15" Retina laptop. Fix the connection between the I/O Board and the Logic Board.图片
产品
$9.99
Replace an I/O board compatible with the Mid 2015 MacBook Pro 15" Retina and fix problems with display, and data connections. Includes the USB, HDMI, and SDXC ports.图片
产品
$36.99
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Jeff M 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 116
总计 335
