跳转到主内容
2.26 or 2.4 GHz / White plastic unibody enclosure
645 个问题 查看全部
Battery not detected, won't charge; strange connector on logic board?
I repair MacBooks as a hobby, and have worked on quite a few A1342 models. I'm working on one now that has me stumped by a couple of things.
Problem: The main problem with this computer is that the battery is not detected and therefore it does not charge.
Things I know:
- Charger will turn orange for approximately 3 seconds when you first power on, but then resets to green
- No water damage
- Computer displays "there are no available batteries" in top right of screen with [X] where the battery should be when booted into OSX
- I think I was able to get it to say "not charging" a few times (I think this was immediately following the slew of SMC resets), but I can't get it to repeat that now
Things I've tried:
- I have tried multiple, known-good batteries
- I have tried multiple, known-good chargers (both 60W and 85W varieties)
- I have tried multiple, known-good magsafe boards
- I have reset the PRAM (cmd,opt,p,r) and SMC (shift, ctrl, opt, pwr) multiple times
- I have tried the "power button down for 10 seconds" and the "power button down for 5 seconds, plug in charger, wait 5 seconds" methods, each to no avail
- I have re-installed OSX, both Snow Leopard and Lion
- I have tested the RAM and RAM slots, both are fine
Is there some fuse that controls battery recognition/charging that could be blown? Similar to the way the backlight fuse can blow, etc. If not, what should I check? There's no water damage and no other damage. I don't have a schematic for this board (820-2567-A) so I can't tell where the battery/charging circuit is.
Other things I noticed:
- This logic board, for some reason, has a connector on the board that I've never seen. I searched on eBay and Google for a picture of one like mine, but could not find any. It looks just like the bluetooth board connector (and is in fact located right next to it, near the fan) on the logic board, but it's twice as long (same width and pin layout and everything). What is this connector for? There's nothing to plug into it in the case, and I've never seen one before. It looks factory-done.
Edit: I can't get it to let me post a comment to your answer, so I'll just edit here.
I have tried everything you mentioned with no success. Something else I noticed tonight, though, which is very strange, is the fact that the laptop WILL run off of battery perfectly fine! I accidentally pulled the charger out while booted into OSX, and the laptop stayed on...so I left it unplugged. It ran fine for 10 minutes off of the battery, despite showing the "[X]" icon in the top right (it tells me there's no battery available, but I'm running off of it).
When I plug the charger in right now, running from battery and booted into OSX, it turns orange, but then to green, so not charging.
I'm baffled. The computer still is not charging, but now it shows the "[X]" although it runs from battery fine (the screen even dims when I remove the charger...so it obviously detects the change in voltage from charger to battery power.
Any clues?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 12
3条评论
Hi.
Im having same problems and tryed to do things from XnriquXs list but my macbook wont start after command+option+P+R .
完成的
First, I appreciate everyone helping out. I just found this forum. I too am having battery issues, with a replacement 65 watt battery. But the mid 2009 does seem to recognize... sometimes.... Sometimes it doesn't & battery depletes too fast.
Anyway, I am gonna try the MacBook Pro Unibody 13" MagSafe DC-In Board replacement & try to let ya'll know if that helps???
Wish me luck!
tcasey001, have you made sure the replacement battery is same wattage, etc as old one? Sounds like that replacement battery is the issue?
I deal with battery tools in my construction, day job & believe me there are some junk ones straight outa the box!
完成的
i found out it was the battery i send back and brought a new one from a store....they took a look at the battery and found it was not good...second new battery works well..
完成的
添加一条评论
3个答案
已选择的解决方案
I have repaired many macbooks with the same or similar problems. Sometimes the macbook wont recognize the battery.
Here are some things I have done to fix theses problems on some macbooks:
  • Disconnect removable devices from the macbook such as USB drives, firewire drives etc.
  • Remove any discs from the superdrive.
  • Disconnect the charger.
  • Remove the battery.
  • Press and hold the power button for 10 seconds.
  • Connect the charger while still holding the power button, keep holding the power button for 10 seconds. (Note: This must be done WITHOUT THE BATTERY)
  • Turn the macbook on and immediately press and hold command+option+P+R keys. Release the keys when you hear the apple chime sound 3 or 4 times. (must be done before you see the white screen at start up)
  • Shut off the macbook when you get to the login screen or the desktop.
  • While the macbook is OFF press and hold Command+Option+Left Shift+ Power Button for 5 seconds. The sleep LED will go crazy and you might hear a loud tone coming from the speakers. Press the power button one more time to restart the macbook.
  • Again shut off the computer and remove the charger.
  • Install the battery and try to turn on the macbook.
  • Check to see if the battery will charge now and if the macbook will recognize the battery.
If doing all these things does not work then there is one more thing that you can do that has worked for me in the past BUT I AM WARNING YOU, IT IS DANGEROUS SO TRY AT YOUR OWN RISK.
  • Remove the charger.
  • While still holding the power button connect the charger.
  • While still holding the power button and the charger is plugged in connect the battery.
  • If the LED on the magsafe turns bright green then the problem is solved and the macbook is recognizing the battery again.
I hope this helps, good luck!!
这个答案有帮助吗?
得分 21
18条评论:
I tried both of those methods and still i have the x over my battery.. the led light on my chagrer isnt coming on anymore. my battery is completely dead. i know this because when i press the idicator button it doesnt even light up anymore
完成的
Have you checked the components of the sensing circuit for the battery?
完成的
Thanks for saving my Mac. I have a dead battery and replace it with 3rd party battery then it went wrong. Coconut battery shows the new battery still holding charge but my macbook air(mid 2011) show warning to replace the battery and sometimes show no battery available. Tore it down and did what you suggested.
完成的
Thank you XnriquX! We had a MacBookPro9,1 model A1286 with an intermittent problem where the battery would not be recognized (X in the battery icon). Prior to this there was a broken cable on the MagSafe 85W adapter and use of a substitute 60W adapter. Even after repair of the 85W adapter cable, the MacBook would only recognize the battery as being present for a few moments each day. We used your first 12-step method above, and now the MacBook recognizes the battery, charges it, and can run some time on battery without the MagSafe charger.
完成的
After plugging in my Magsafe 1 for my 2009 Macbook Pro, the plug end sizzled a bid, and I immediately disconnected. After that incident my MBP wouldn't recognize my battery and the fan would run very fast. After completing your instructions my computer is back to normal. Your help has been invaluable.
完成的
显示更多的13条评论
添加一条评论
@Chris Bayrd
As for your problem (as well as the others) battery issues are always the biggest problem in any laptop (Apple or any ones else's). The Problems can be broken down into three parts:
  • The chargers condition
  • The batteries health
  • The charging logic internally in the system
Charger - Many people fail to maintain their the chargers cords. Twisting them into a knot and expecting it to still work! Also damaged connectors can cause issues. A shorted cable not only not charge the battery or over charger it, it can often damage the charging logic internally in the computer which can be a very expensive repair!
Battery - Over time the battery breaks down the life span of most batteries is around 800 - 900 cycles. Download this little gem: coconutBattery. If you had a bad cord your battery may have been over charged causing it to swell. This can then effect the keyboard & trackpad. Sadly it time for a new battery if this happens and you'll need to check your charger.
Charging logic - The MagSafe connector is often the first signs of problems as the insulator is melted and/or the pins are discolored. Dirt and metal crumbs can also cause problems! Make sure you keep the connector surfaces clean. Don't use anything metal inside the laptop connector! As you don't want to create a short.
The MagSafe charging logic can also be damaged by static electricity! Maker sure you don't zap your system around the connector or logic board if you have opened your system up. Follow good ESD practices.
Both of these conditions often require deep diagnostics to save the logic board. Or its time for a replacement logic board.
I all most forgot the spoiler here! Liquid damage. Anytime you spill water, coffee, soda or juice into your system all bets are off! As the damage can be quite large.
Lastly, the MagSafe LED and the battery checker LED's are also very useful to diagnose problems!
这个答案有帮助吗?
得分 1
1条评论:
Oh my goodness! I've been looking for a solution for months after my computer would not charge the battery. I even bought a new magsafe charger... a changed out the charging port, new battery, reset the sms... nothing worked! Until now!!!
完成的
添加一条评论
I have an Amber LED for the first time in a long time after resetting SMC and then PRAM, so this works, but my battery is long dead.
Still going on the Macbook 2008, but the compatibility issues have me in a corner, if not now then soon.
The computer is still good for a while longer I know, but not long enough to bother buying a new battery and all the requisite RAM and SSD upgrades I don't think.
Just a testimonial to how long these things last. Go for it.
这个答案有帮助吗?
得分 0
1条评论:
I tried replacing the A1309 battery in my early 2009 Macbook Pro 17" but the ribbon connector on the new one doesn't seem to fit tightly enough in the internal socket with the result that I don't get the Amber charging light on the magsafe adapter. I tried another A1309 battery but had the same problem. Can anyone please help ?
完成的
添加一条评论
添加你的答案
Steven 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 30
过去 30 天: 153
总计 144,586
