跳转到主内容
PS5 游戏机于 2020 年 11 月发布,其视觉效果大幅升级,并配备了创新的全新 Dualsense 控制器。太空时代的黑白配色方案与过去的 PlayStation 设计大相径庭。
PS5 SSD installation - replacement screw and spacer
I tried to install a new WD SN850 SSD in my PS5 last night. However when I went to remove the screw and spacer in the bay, the screw was stuck, and I just can’t remove it at all. I’m looking for a replacement screw and spacer to fit the SSD. Does anyone have any recommendations from Amazon UK or any other retailer? I’ve contacted Sony, but they haven’t got back to me at all, which isn’t a good sign. Many thanks in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
9条评论
I got the same problem too. Currently trying to find similar screw and spacer in SEA market but can't find nothing
完成的
@Akifan Jannata I still haven't had a response from Sony Customer Support. I'd happily buy the screw and spacer if I knew what I was looking for! So frustrating!
完成的
Hi i have the same probleme if one of you find the good dimension for the screw can you tell me
完成的
To replace the screw that holds down the M.2 access cover, use a M3 × 16 screw.
To replace the screw that holds down the M.2 SSD drive, use a P3 × 10 screw.
To replace the spacer that supports the M.2 SSD drive, use a spacer with the dimensions φ5.5 x 3.95 mm.
完成的
Where do they sell the spacers? I can't find it with an internet search.
完成的
显示更多的4条评论
添加一条评论
5个答案
已选择的解决方案
I have found a screw that has done the job for me. I got the M3-0.5 x 10mm flat head phillips screw, which fits perfectly. I didn't need a spacer either. The screw did the job on it's own. Hope that helps
这个答案有帮助吗?
得分 1
2条评论:
From which UK shop?
完成的
I ordered a new screw and spacer on Amazon. So am I good to just leave the stuck/stripped one in it’s original 110 slot?
完成的
添加一条评论
This is the screw I replaced the original stock screw inside the ssd bay that holds down the ssd.
Update (06/05/2022)
This is the original screw that came with the ps5 that I damaged.
这个答案有帮助吗?
得分 0
2条评论:
4-40 x 1/2 in. machine philips pan head screw fits inside the original ps5 spacer
完成的
完成的
添加一条评论
Here are images to see that the 4-40x1/2in. screw fits inside the ps5 ssd bay.
这个答案有帮助吗?
得分 0
3条评论:
Bro what is the size of screw you displayed in 2nd image
完成的
Is the screw properly fixed with ssd?? And what's the size of it?? Plz inform me Asap.
完成的
Sorry for the late reply. The screw size is 4-40x1/2in screws.
完成的
添加一条评论
https://amzn.eu/d/iJrAFeV
这个答案有帮助吗?
得分 0
添加一条评论
I found this on Amazon UK, "Amazon's Choice" for ps5 ssd screw and spacer
DevineCustomz® Compatible For PS5 Mounting Solid State Disk SSD Screw Replacement Nut Console Motherboard Metal Screws
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kevin McCubbin 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 52
过去 30 天: 220
总计 38,258
