Is the power supply actually dual voltage?
I’m moving to the UK and wondering whether my TCL 55P607 might be secretly dual voltage. I understand it is common practice to label TVs as 110-120V only even though the power supply can actually take 110-240V.
Before I open up the back and take a peek, I was hoping someone else would have an answer. I believe the part number is 08-PN2G10L-PW200AA but looking at the PCB photos online, I don’t see any indication one way or another. Any hints would be appreciated!
7条评论
They sell adaptors so you can safely use devices from the USA in the UK. Might just play it safe n get one
由 brandon k 完成的
@brandon_k
Hi Brandon, It wont work. Those adapters are only for the plug shape. For voltage you would need a heavy, fairly large transformer and then there are the different power frequencies - 60Hz vs. 50Hz. True some items are rated 50 or 60 Hz but you would have to check.
由 mike 完成的
A transformer would work but as @brandon_k said it's heavy and large so I'd like to avoid getting one if I can.
由 szx 完成的
@szxzx
Why not just contact TCL:
https://www.tcl.com/us/en/products/home-...
由 mike 完成的
@mike because the TV has a label on the back that says 110V, so even if it's 110-240V in practice they won't say so. Even if it's only a matter of regulatory approval etc.
由 szx 完成的
显示更多的2条评论
