My 2 year old sprayed water on my tv screen
My 2 year old sprayed water on my tv screen and now I have a fuzzy picture but then also sometimes a good picture. What can I do to get back to a good picture all the time
Hi,
First turn off the TV and then disconnect the power from the TV.
Water and electricity are not a good mix. The impurities in the water causes corrosion and creates circuit paths for the current that were not in the operating design of the TV and can damage the components.
The corrosion is ongoing and needs to be cleaned away using Isopropyl Alcohol 99%+ (available from electronics parts stores).
Remove the back cover from the TV and inspect the boards for any damage or signs of water etc.
Water being sprayed on the screen will be harder to fix as some may have seeped passed the bezel and come into contact with the fine and delicate wire connections to the screen itself. If this is the case these cannot be repaired or cleaned etc. the display panel will have to be replaced. This is easier said than done as finding replacement panels is not easy and their cost if you do happen to find one can be almost half the cost of a new TV.
If the problem is confined to a board there is a chance that it can be fixed by cleaning it and replacing any obviously damaged components or worst case replacing the board.
这个答案有帮助吗?
Hi
Thanks for your reply. Is there no way I can just leave the tv off to dry out as it’s a fuzzy picture and then a good picture ?
Thanks again.
@Andy Gleave
You can try leaving it disconnected from the power for a few days. Remove the back cover as well to aid in drying.
Don't be surprised if it then seems to work OK for a while only to start failing again days or even weeks later.
You may be lucky.
TO add to this, even I struggle with TVs :-(. If I look for an intact panel and bad electronics, it's still near that 50% halfway I will BER it.
This isn't a laptop problem, there's solutions. This is a TV specific issue.
过去 24 小时: 18
过去 7 天: 159
过去 30 天: 708
总计 15,996
