跳转到主内容
加入维修社区 - 创建账户
索尼 PlayStation 5 DualSense 手柄(第一代)的维修指南,拆解信息和支持文档。本产品型号为 CFI-ZCT1W,主板型号为BDM-010。DualSense 系列手柄取代随 PS4 同期发布的 DualShock 系列手柄。
PS5 Dualsense Controller - Faulty 3.5mm Headphone Port
I’m running a split Headphone/USB Microphone setup (Audio Technica ATH M50X headphones, RODE NT MINI USB Microphone) and recently my headphone port has begun disconnecting on my Dualsense controller. It happens when I either rotate the jack inside the port, or if I lightly pull on the jack too (a good example of this is shown in this video as to how loose it is: ''https://www.youtube.com/watch?v=gXyNlGFt...). This is a slight annoyance considering I have to then disconnect everything and reset it all up again.
Has anyone dealt with any similar headphone port issues/replacements?
Thank you!
Jasper
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
2条评论:
I have just removed the jack from my own remote, it is surprisingly more simple than it looks.
完成的
However it is surrounded by micro components right next to it, if you de solder the 4 pins on the edge, the other 3 on each side just push into the plastic assembly, they aren’t secured together. Just gently pull it up after you get the front 4 off and then de solder the pins. Clean it up, and you’re ready for a new one.
完成的
添加一条评论
6个答案
This has happen in my laptop charger port, the best bet is get a new cable and check the port by a technician.
这个答案有帮助吗?
得分 0
添加一条评论
Unfortunately I've tried multiple sets of headphones with no difference whatsoever and the headphones I'm using work fine in other devices with no issues with connectivity. I'm going to try to return the controller through the retailer I bought it through, however as shown in the video, it seems to be a consistent issue across many controllers. Will keep this post updated with any progression!
这个答案有帮助吗?
得分 0
添加一条评论
I guess the headphone jack is NOT available as a spare part from Sony
这个答案有帮助吗?
得分 0
1条评论:
Mobilesentrix offers them for a few bucks
完成的
添加一条评论
Any update on this issue?
这个答案有帮助吗?
得分 0
添加一条评论
Absolutely nothing :(
这个答案有帮助吗?
得分 0
添加一条评论
I have a problem with one of my ps5 controllers where i would plugg in my headphones and the sound from my head set had sounded like static noise so i tried another controller didn’t have that issue my controller model is cfi- zct1w
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jasper Matthews 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 13
过去 30 天: 67
总计 7,782
