跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
Should LCD turn on when thats the only thing plugged in?
Hi,
Im pretty new to repairing iphones, fixed a few ipod touches so just have a quick question, ive taken the front assembly off my iphone, as im trying to work out if i need a new logic board or lcd, just wondering if the lcd would turn on if thats the only ribbon connected? as i thought it may be a quick way of testing it?
The iphone responds and you can see it in itunes, theres just no display!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
Yes, the LCD will turn on if it is the only thing plugged in. I recommend replacing the LCD before you replace the logic board.
这个答案有帮助吗?
得分 2
2条评论:
try holding home and power for 10 seconds until the apple appears and then release the buttons and allow to reboot. Sometimes that works..if it doesn't then replace LCD.
完成的
Thanks, ill have a new LCD arriving in the next few days. So ill will plug that in (without the digitizer or back-light cord) and see what happens, thanks for the advice :)
完成的
添加一条评论
添加你的答案
josh williamson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 341
