跳转到主内容
Model A1046 or A1095 / 1280x854 screen resolution
118 个问题 查看全部
Fixing the backlight and Testing the backlight
there is no light but the LCD works using a flashlight i can see the LCD i like to know the volts that the backlight needs so i can test the light and is there a way to do this then i can find out if it is the inverter or the cables
there should be a way to feed the backlight with external power
thank you
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Being able to still see the desktop usually indicates an inverter failure or inverter cable failure. Try moving the screen up and down and see if anything changes. If it does, here's the way to replace it: PowerBook G4 Aluminum 15" 1-1.5 GHz Inverter/Antenna Cables Replacement
Here's just the inverter without the cable: [关联产品丢失或禁用: IF154-038]
Here's just the cable: [关联产品丢失或禁用: IF154-044]
这个答案有帮助吗?
得分 4
添加一条评论
添加你的答案
rick3037 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 919
