The Honda General Purpose Motor model GX160UT2 is an air-cooled, four-stroke, overhead-valve, 163 cc, 4.8 HP (3.6 kW) engine. Supporting sub-models QWX2, QX2, RH2, TX2.
Pull cord will not pull. Flywheel works perfectly, when i pull the cord, and then align it back , it does not retract. The flywheel rotor has limited movement
Broken spool spring - common failure. If you're not familiar with recoil spool repair, take it to someone who is. You could try YouTube, but mistakes with highly spring tensioned objects get ugly Fast.
由 Kevin Sargent 完成的
