跳转到主内容
Toshiba Satellite C55-A5100 15.6in Laptop Intel ® Core™ i3 - 312 0M Processor 2.5GHz 6GB 750GB DVDRW
5 个问题 查看全部
Toshiba Laptop no signs of life ( CMOS Battery )
Hello! I made little scraches under cmos battery by mistake and after i put back cmos battery Toshiba Satellite laptop doesn’t start. There is no power ( its connected to power ), doesn’t show battery or no other light. Totally no signs of life. I want to ask the problem is on motherboard or another thing? How can i check and proceed? Please help me, thanks!
Update (08/09/2021)
Here: https://ibb.co/Fn52vm8
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
If the laptop worked fine BEFORE you scratched (?) the CMOS battery then just replace the battery. The CMOS battery is how the laptop keeps all the settings for the BIOS/UEFI - how the computer knows what to do.
Let us know how it goes. These “CR2032” batteries are cheap and can be purchased just about anywhere.
这个答案有帮助吗?
得分 1
2条评论:
I understand but pins under the cmos battery doesn’t hold battery itself.. I search in google and CMOS battery cannot cause no booting ot no power, but thanks anyway i will try!
完成的
@FortniteshopBG
A corrupted BIOS can cause no booting and no lights. I've dealt with that problem at least 4 or 5 times but with the CMOS battery removed usually something will happen as that will cause the BIOS to reset factory default.
完成的
添加一条评论
Can you provide photos of the affected area?
这个答案有帮助吗?
得分 1
1条评论:
Looks like damaged trace(s), which can be repaired using solder or jumper wire. Here's a video illustrating the basic idea: https://www.youtube.com/watch?v=qLf1gBg7...
完成的
添加一条评论
添加你的答案
FortniteshopBG 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 21
总计 788
