跳转到主内容
初代iPhone(又称iPhone 2G)。型号为 A1203,存储容量有4GB、8GB、16GB可选,机身颜色仅有黑色搭配金属铝。维修初代iPhone是容易的,需要耐心,一些工具和焊接技术。
224 个问题 查看全部
Broken Sim Reader Pins
Hello,
I always wanted a first generation iPhone and I bought a first generation IPhone to repair. I realized that my device is not reading SIM cards. Then I opened it and saw the broken pins. Can I just buy a broken motherboard and replace the sim slot? If not how could I fix it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
I have replaced sim holders on a lot of iPhones but not this model. It looks easy enough. I am not sure how much heat you will need to melt the solder on these models, if you flow the joints with low melt solder you shouldn’t have a problem although you will probably need a hot air station as well as an iron.
The hardest part will be finding a non-working one to buy.
这个答案有帮助吗?
得分 2
1条评论:
Thank you so much?
完成的
添加一条评论
添加你的答案
Batu Köseoğlu 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 7
总计 50
