跳转到主内容
2nd-generation magnetic AC power adapter for MacBook products, first released in 2012. Not compatible with previous generation systems. Available in 45W, 60W, and 85W versions.
26 个问题 查看全部
Magsafe 2 85W charger will not charge 2015 MacBook Pro
I have an old 85W Magsafe 1 charger with a T-tip (yes, it’s an odd ball one) that I converted to a Magsafe 2 T-tip by resoldering a brand new Magsafe 2 T-tip cable. It charges all all of my laptops without issues:
  • 2013 13” MBP Pro
  • 2014 15.5” MBP Pro
  • 2015 13” MBP Air
They all show light up solid green when charged up or solid amber when charging.
Unfortunately, the charger won’t power up my 2015 13” MBP which has the battery disconnected. The amber light on the cable blinks and then turns off. My other magsafe 2 chargers will at least power it up with a solid amber light. As a test, I tried at least three different chargers and they were able to power it up without issue.
I highly doubt I botched my conversion. Are there other differences either in the MBP 2015 Pro circuitry or the Magsafe 1 circuitry that may cause it not to charge.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Ah, you really can’t use it as the power is lower. To add to it the MagSafe connector has a ID within it to ID the charger and the voltage to the system to prevent improper usage.
Teardown and exploration of Apple's Magsafe connector
Time to get the correct charger for your system. And please for your safety and your systems use a real Apple charger! The chargers you find on Amazon and eBay are knockoffs which will damage your system and have been known to set buildings ablaze!
这个答案有帮助吗?
得分 1
添加一条评论
I keep a couple of these Apple MagSafe to MagSafe 2 Converters around. They are cheap and work very well.
https://www.googleadservices.com/pagead/...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
AppleGuyPie 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 9
总计 441
