跳转到主内容
This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
318 个问题 查看全部
DS Lite P6 Connector Black Clamp Popped
I was in the middle of reassembly of my DS Lite. I tried to detach the touch screen ribbon cable that connects to the P6 plug but the way I hold my DS while detaching, the black clamp that holds the ribbon cable securely just popped off. Good thing that I still saw the black clamp as it is too darn small. Is there are any way to snap it back in to the connector? If not, are electrical tapes helpful for holding the cable securely?
The picture below is not the actual. Just a reference. Thanks in advance!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
I had this exact same problem, so I tried holding it down with a bit of Blu Tack, but that didn’t work very well.
I recently came across this video https://www.youtube.com/watch?v=dRxePF-d... which demonstrates the replacement process of the P6 connector. You need a soldering iron to do it, though, so I will be giving this a go once I get my hands on one.
这个答案有帮助吗?
得分 0
1条评论:
Yeah I already saw that video and I don't have the skills to replace the connector. I managed it get it working by putting an electric tape to hold it in. The most difficult part was putting the motherboard back in the case while holding the tape in securely. And the touch screen fortunately still works! :)
完成的
添加一条评论
添加你的答案
Robert Isidro 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 17
过去 30 天: 69
总计 1,902
