跳转到主内容
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
iPhone X boot loop when the digitizer is connected
Hello IFixers,
The screen of my IPhoneX went completely black after I dropped the phone into the pool.
(First some green lines then just black)
I bought an original refurbished screen from eBay and installed it yesterday.
When I power on the phone it starts looping during the boot process. It shows the apple logo for a few seconds then it shuts down and starts again.
I tried several things, including isopropyl alcohol bath for the logic board, but nothing helped.
Then I tried to disconnect the digitizer and the phone booted without any issue and the screen looks perfect.
I checked the digitizer connector on the board and on the flex cable, but couldn’t see any damage on those.
Could it be a faulty digitizer? The seller told me that it was fully tested and in working condition.
Or maybe the logic board is damaged permanently?
Do you have any suggestion?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
I typically don’t like to source parts from eBay as they’re not always sold as advertised but anyways there could be a chance it’s defective or that the liquid damage is a bit deeper than just the screen. If the old screen works, can you test that one as well?
这个答案有帮助吗?
得分 1
1条评论:
Yeah definitely attempt to connect the old screens digitizer to see if the issue is on the logic board or the replacement screen. eBay part would be my bet though.
完成的
添加一条评论
Yes, it’s the replacement screen.
I bought a cheap aftermarket one and the phone works perfectly with that.
Unfortunately it has a thicker frame that I don’t like, so I’m sending back both screens and I’ll try to get an original one.
Thank You for the support!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kadamx 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 69
