跳转到主内容
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
1199 个问题 查看全部
iPhone X Screen Burn
So today I repaired a customers IPhone X screen. The customer had a screen burn with the keyboard being the location of the burn. Due to this being an AMOLED screen I am familiar with this issue. However after putting on multiple different screens, the screen burn was still there. Any ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Are you copying the screen data to the new screen? If so I have seen this happen a few times where the burn gets transferred as well as the data. I don’t think there is much you can do except delete the data off the screen and lose true tone.
这个答案有帮助吗?
得分 2
添加一条评论
It could possibly be a problem with the screen’s connector on the logic board. Depending on the color and intensity of the burn in, a pin on the motherboard could possibly be burnt or have another problem with it. It could also possibly be a capacitor however I would expect it to be a pin on the connector. Hope this helps!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Neal Thomas 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 16
总计 382
