跳转到主内容
发布于2018年10月26日。型号A1984,A2105,A2106,A2108。 提供GSM或CDMA / eSIM,nano-SIM或双SIM / 64,128或256 GB /黑色,白色,蓝色,黄色,珊瑚色或红色。 (发音为“iPhone 10 R”)
468 个问题 查看全部
How to remove iPhone XR motherboard bottom shield?
Hello, I am trying to remove the bottom shield of an iPhone XR motherboard to replace U3300, however I have noticed that it is a lot harder to get off than other shields. By “bottom shield” I mean the shield under the battery connector. I tried 480c of heat, which is the maximum my hot air will go to, however it did not come loose. Maybe I need to heat it for longer? I am just concerned that I may damage or heat the motherboard too much. Thank you so much for your help
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
These shields are not the easiest to remove as they hold a fair bit of ground plain. I use full heat and air flow with a large or no nozzle. The shield you are talking about should come off when the hot air temp reaches around 400 degrees.
All hot air stations are different; the temperature displayed may not be accurate due to the age of the machine or its make.
You are right thinking that exposed heat might damage the motherboard. The other method you can use is to cut it off. I see a few that come in with prior repair attempts which have had the shield removed this way.
这个答案有帮助吗?
得分 2
添加一条评论
Have you checked out the teardown?
iPhone XR拆解
这个答案有帮助吗?
得分 1
1条评论:
Yes, however unfortunately it didn’t say much about how to remove the shield, although was really descriptive on the chips underneath them. Thank you for your answer though!
完成的
添加一条评论
添加你的答案
Colby Morris 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 5
总计 317
