跳转到主内容
The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
318 个问题 查看全部
Disassembled back panel - extra part!
Hi! I took off the back panel and then reassembled. Problem is-I have an extra part! I don’t know where it goes.
model: w10110637
kenmore elite smartheat quietpak4 electric dryer from 2007
I’ve included two photos of the extra part.
Please help
thank you
Update (07/20/2021)
Could it be the bracket - upper rear bulkhead?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
@eoeoeoeo cant see your pictures ;-) Try again using this guide. The pictures get attached to your original QUESTION please.
在已经存在的问题里加入图片
完成的
添加一条评论
1个答案
已选择的解决方案
Hi @eoeoeoeo,
The model number you quoted (W10110637) shows up as the part number for the tech sheet for a lot of dryers
Please confirm the dryer's model number?
It looks like part #31 in the bulkhead parts diagram of this this model, which is in the list of those shown in the link above
这个答案有帮助吗?
得分 2
2条评论:
Thanks, jayeff! I agree - I think it is #31. I was able to put it back where the diagram indicated. Problem solved - I think!
The model # is 11087872601.
完成的
Hi @eoeoeoeo
Glad that you got it sorted OK.
Here's the parts list for your model.
Also if needed for the future the tech sheet
FYI I've reopened your two deleted comments (and then deleted the duplicate one) and also restored your lost reputation points on Ifixit. (-100pts for each question, answer or comment deleted as spam)
Sometimes Ifixit's iRobot gets a bit too aggressive and thinks that long number strings e.g. device model numbers, are spam phone numbers so it auto deletes the question, answer or comment as spam.
It's still learning ;-)
Cheers
完成的
添加一条评论
添加你的答案
Emily 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 169
